I have Bilstein shocks and eibach pro springs that I have not put on my car YET. I am keeping stock wheels. Question is, if any of you have this setup and running stock wheels or same size aftermarket wheels, What size spacers are you running to make flush? Thanx in advance!
Discussion Starter · #2 ·
Sorry, I did find some info, I think 10mm in front and 20mm in rear is what some ppl are running? I would like to be hella flushed but I know that could look a bit funny without an aggressive tire and wider wheel. I just do not want it to be too "sunk" in. thankx
go with a 15mm front and 20mm rear. You will probably need a fender roll also. This is probably most safest set up if you don't want to modify fenders really. Some members in the link I listed below have even more aggressive but need more fender work. Your choice. Check out the link for more info.
http://my.is/forums/f95/flush-set-up-stock-rims-380627/
