1 - 12 of 12 Posts
new to the community.
Jump started car, car started up and gauges were all fine.
Installed new battery and then engine cranks but won’t start and also Here are items working and not working after change in battery
Working
Horn
Head lights
Vanity lights
Power seats
Security light and door chime
Not working
Combo meter or Gauges
No odometer, fuel gauge, no warning or check engine lights
Obd2 port
Radio
AC climate control
Moonroof
Power doors/windows/
Wipers
Remote access
Engine cranks and no spark.
Fuel pump working
please help me in troubleshooting this issue.
Is the positive and negative cable connected to the correct battery post? Positive post should be closest to the engine
Check your fuses and relays probly blew a relay imo
i did power test with 12 volt circuit tester on all fuses in three locations and observerd that there is no power on any fuse on driver side fuse box and no power on 1st row and 3rd fuses on passenger side fuse box.
these fuses look fine, I have swapped fuses and observerd the same pattern.
any suggestions
where should I look
Discussion Starter #7
If it was working fine before the battery swap. Check your cables.
which cables should I look specially
Discussion Starter #10
My bad.. I should have been thorough while checking fuse, I thought I have checked all fuses but after giving 3rd of fuse checks Noticed 120 Amps ALT fuse blown.
from wiring diagrams it seems like this fuse pretty much covers everything in the fuse box 2 and some in 3
I got the fuse today and will keep posted after installing it.
thank you very much for all your help
Changed 120A ALT fuse today and everything came up fine. Still car won’t start. when i check for fuses, there is no power on 7.5A starter fuse, 10A tail fuse, 7.5A panel fuse.
any ideas?
1 - 12 of 12 Posts
