My '03 has about 144k and it needs a clutch. I am going to run the NA supra flywheel along with a SouthBend Clutch (unless anyone has a better option in mind). The engine is stock but I plan to run some low boost through the car at some point down the road for around 300 wtq.
SBC has a stage 1 daily rated for 235 wtq, or a stage 2 daily rated for 295 wtq. I'd like to run the latter but I'm wondering if "over-clutching" is anything I need to worry about. Also I'm wondering if I even need the stage 2 for 300wtq. 300 is pushing the oem NA Supra clutch to its limit, but the SBC stage 1 daily is upgraded with a stronger pressure plate compared to the stock clutch, so perhaps stage 1 will work? Also note that I'm wanting to protect the transmission as much as possible. Anyone have advice or previous experience to share with me? Thanks!
I'm not familiar with South Bend Clutches, but I had a Clutchmasters rated for 550hp and a Drift Motion rated at 550hp - and both had nice easy pedal effort. Both were ceramic puck-style clutches, however, and engagement has harsh and chattery. I don't recommend ceramic pucks.
It'll take very little boost to hit 300wtq, so I definitely wouldn't install a clutch rated at 235wtq if boost is part of the plan.
Regarding your transmission: You'll need to be gentle on a W55 if you want it to live with boost.
2001 AR5 Swap, Built NA-T, Standalone
When do you really plan on boosting it? I wouldn't do anything too far over an OEM replacement type unless you're experiencing slip.
