http://www.tanabe-usa.com/coilovers/s-sII.asp
I had them installed at Dynamic Turbo and they took forever doing this, but got it all done right.
Pros:
Ride is actually quite smooth so far. A little harsh over some bumps but quite smooth. Spring rates are not too bad at all. I have not touched or played with the dampening on the coilover yet. They came out of the box on 4/8 in the rear and 2/4 in the front. This setting is fine, but I will venture to play with them setting wise this weekend. The drop i have set at 2 finger gap with stock 17's (which are for sale with tires).
Cons:
Adjustment knob for the rear is way under the car. It is a knob that can be easily broken or coroded off (by looks and location). Other than that, I need a rear camber kit or adjustment. I have some negative camber.
Update:
Installed my new wheels on the drop, and the camber issue was still pretty bad. Rolled over to a suspension shop in my area, and they adjusted the camber to 1.4 degrees in the rear using the Tanabe Mounts. So now I guess I am ok.
Pros:
Cons:
Update:
