241 - 251 of 251 Posts
Discussion Starter #243
Update:
It's been busy few weeks for me. Purchased a new car for the family. Back SEMA 2015, group of friends rented a Infiniti Q50 3.7 in Vegas. I was driving around and put about 100 or so miles on it. Car was comfortable and had decent pick up in speed. At the SEMA, I ran into a guy who put GTR R35 motor into the Q50, and though how it would fulfill my GTR desire. Well, Nissan finally came out with Q50 Red Sport 400, which I recently purchased. Car is just what I needed. Comfortable daily my wife can drive and enjoy, switched to Sport + mode and car comes alive and becomes a beast with 380WHP (thats what some of the stock RS400's been dynoing). Here are couple of pictures of the car.
With both of my Daily, RS400 and IS300 Wagon.
Regarding Rotaries...
I've decided to clean up some wiring to get ready to put a new set up in the car.
To do it right, I also needed to pull the dash and clean up the hacked up 20 year old interior harnesses.
More to come next week..
Discussion Starter #245
Update:
Over the weekend I was able to do some wrenching on the car.
First installation of Sakebomb garage upgraded swaybar mounts. These things are beefy and well made. I'll be using a new Tripoint swaybar with these.
Another thing I was able to do was check the compression on my 1973 RX-3. I recently got the Rotary Compression Tester (RCT)'s battery operated compression tester and wanted to compare to my Mazda Specialty tool compression testers (old thermal and digital).
After warming up the car, I've tested just the OE digital and RCT testers. RCT unit uses 9V battery and it has automatic altitude calculation. Its super well made and easy to use. All you have to do is warm up, kill the ignition and fuel pump, install the sensor in the trailing plug hole and crank the motor. I did a facebook live video (https://www.facebook.com/Herblenny/videos/10154392837808927/) hope some of you can view it.
Anyhow, here are the results from the RCT:
Front
[/URL]
Rear
Not bad for 20+ year old engine :)
Here is the RX-3 warming up before the test.
Discussion Starter #246
Update!
Couple of months ago I ran into Facebook post about Champion Autoparts, "Search for a Champion 2017" promotion.
I've decided to enter and a week ago, I was chosen as one of the top 25 finalist!!!
I would greatly appreciate it if those of you following this thread to vote for me. I have an unique project that I'll be working on later this year and would be nice to win this to support that build. If I win, I'll share what that is the day of winner being announced... otherwise, I'll be keeping it hush hush for little bit longer :)
To Vote, goto: 2017 Search for A Champion Grand Prize Voting Now Open!
Voters can also win prizes from Champion. Thank you for your support!
Discussion Starter #247
Update:
I finally had a weekend to do some car related stuff.
First my daily IS300 Wagon...
My RedSport had ceramic/nano coating from previous owner and so far I was very happy with the results. So, I've decided to put the coating on my IS300.
I've decided to try 'Stay Fresh Car Care' as I've had great luck with their detailing products in the past.
Stay Fresh Car Care / Premium Car Care Supplies
I went with HCC9, 50mL kit with 8oz Quick Ceramic detailer. (less than $100).
First, I cut the car using a random orbitor and various pads and such (3-5 hours)
Wiped it down with isopropanol (rubbing alcohol) to remove any residue from wax, sealant, oil etc. I than started to apply the HCC9 using supplied applicator. This process wasn't bad. I was told to do small section at a time but the temperature was kind of cool and HCC9 wasn't drying that quickly so I did panel at a time. First layer of application including alcohol wipe down took me about an hour.
I had about 30-40% of the ceramic coating leftover so, i messaged the owner of Stay Fresh about if second coat is necessary. He said it will help. He suggested I use the remainder of the bottle on the car. He said you can apply the second layer after about an hour after 1st application. I decided to let the first layer harden overnight.
Oh, no water can touch the car during hardening process.
Here is the result:
Definitely shines pretty decent. I was driving home last night and it was raining. I could tell this stuff was working. In heavy traffic, everytime I came to a stop, a good amount of water from the roof of the car will rush towards the front windshield. Moving forward, I could see the water coming down on my rear window. This is first time seeing such a thing. To maintain, no waxing, no soap, just water to clean the car for the next 5 years! Benefit I see with this is daily driven cars and car that might be loosing little of clarity due to fade.
Anyhow, now about the RX...
I'm re-doing my RX-7 for a guaranteed feature with SuperStreet Magazine. So, I've decided to re do my turbo set up and support my friend Zach, Addicted Performance. He also supports my event, 'Deals Gap Rotary Rally' (DGRR) and helped me by answering many of my questions regarding turbos and tuning.
I've decided to go with his Borg Warner EFR kit. Craftsmanship on the kit is top notch!! Also, Zach is a great tuner and will be taking my car to his shop when its done for a tune. Hopefully during DGRR and unveil the car there.
Turbo is Borg Warner EFR 8374 IWG with Turbosmart upgraded Bypass valve and IWG actuator.
I've mocked it up on my spare 13B-REW motor, and this is using REW intake manifold. I'll be also mocking it up with Cosmo 13B-RE manifold later on.
Also, vote for me!!! You can vote daily!!
Thank you all for reading this thread!!
Discussion Starter #250
To follow up on the ceramic coating, here are couple of video of my IS300 Wagon showing how water just beads off.
Water on the hood.
https://youtu.be/m6-SsEQ3eUs
Close up on the fender.
https://youtu.be/vJZRBC1OL98
Besides this, not much is going on. Spent most of the weekend hanging out with my son and dinner with close friend. Otherwise, not much of a car week :)
Not much to update. Been busy spending time with my son over the weekend and work.
But I was able to sand down my Mazdaspeed Carbon Fiber front bumper lip and clear it to bring the shine back. Than replaced my 99 lip from my SSM FD.
These pictures are top quality! Where did you get those headlights? I've never seen any like them before
