I had an error 3 on my CD player and thought I would fix it by disconnecting the negative terminal on my battery (according to what the forums said here). When I plugged it back in, the AM/FM only works. I pressed the CD/eject/load button and the head unit has no reaction (doesn’t do anything). I looked at fuse #17 and #37 and both look fine. Is there anything I could do?
I’m not looking to change the head unit for an aftermarket as I want to keep my car OEM and I don’t want to swap it for another OEM unit as it looks brand new and it still has the original warning sticker on it.
I don't want to give up on it yet. I just got a junkyard unit and I'm going to open it up to learn how the mechanical parts work inside it, practice on it, then I'll do it to my own head unit.
If it does not work, then (plan B) I'll just listen to the radio and install bluetooth from Grom or USASpec. Then I can listen to music from my phone instead of the CD player.
If I can't get the CD player to work then (plan C) I'll send it to a repair place and have them fix it for me.
Update:
I’m still not able to get it to work. But the weird thing is that I installed USA Spec to add Bluetooth to the head unit just to see if it will fix the issue and the CD button magically works. However, it will only let me go in Bluetooth mode though, and I can’t go to CD mode to eject the CDs out. When I unplug the USA Spec device, it goes back to normal and the CD button is unusable. I’m just going to get it diagnosed and fixed at a stereo shop.
Just for fun, here’s the warning sticker on my head unit. Anyone still remember these?
134357
