1 - 20 of 118 Posts
Got my manifold, turbo, downpipe, oil feed & return, intercooler & piping, IK24 plugs, and injector clips installed.
Need to install the injectors, fuel pump & return kit, Blitz SBC, EFI 1000 wideband, and TEC3.
I ran into a few problems so far, removing the stock exhaust manifold and y pipe was a pain in the ass. Damn bolts wouldn't want to break loose and the O2 sensors didn't want to come out either. I cracked my fuel rail when I tried to tap my 1/4 NPT fitting. I was missing an intercooler piping and another piping had the HKS BOV flange welded on the wrong area. I was missing 2 exhaust gaskets. My TEC3 is missing 2 bolts to secure the trigger wheel adapter. Looks like I might be able to finish if I'm lucky late Thursday night but more than likely this weekend.
Ok pics from the install...
My S4 crew comes to help out.
Also what O2 sensor did everyone plug into their downpipe? Did you use the one of the pre-cat or the post-cat?
Looking good +rep for the boost update.
Lambchop, if my memory serves me correctly, use the post cat 02 sensor for bank 1 sensor 2 on the downpipe, then the 02 bung under the car is the old y pipe sensor which is bank 2 sensor 2.. The 2 sensors that plug in near the water pump should be completely unplugged.
Ok, so the O2 that's plugged closest to cylinder 6 should go into downpipe and the two that are plugged closest to the water should be unplugged completely. Many thanks Malek.
looking good Leo. Props to you for installing this at home
let me know if you need anything from BL ;)
Podiatrist
The car uses the pre-cat 02 sensors more than the post-cat.
I would put a pre-cat 02 sensor in the downpipe.
Come on Leo. Think with your dick more. It'll work out better that way.
leo, for the dp o2 sensor, i am using the one that has a wire clip (plastic)to it. so, whichever o2 sensor that is cliped on here:
good luck!
Jusat confirming with you that Malek and De are correct.
Looking good so far! Mind me asking how much you paid for the kit?
If you have any questions regarding the Tec3 tuning, ask either Malek or I.
Kane
yea...leo had a long wait for his parts to arrive
how long did it take for your parts to arrive?
BigDaddyRich said:
You need at least one of the Sensor 1's in the DP. whether it be Bank1 or Bank2.
Damn almost a year for a BL kit to be running :)
Not if he's using a Tec3 with the PFS box, they use O2 sims for the first two o2 sensors.
If no PFS box or equivalent, then you are correct. But I believe the BL kits that sold with Tec3 also came with a PFS box or equivalent.
Kane
Discussion Starter #14
Kane
Don't got the PFS black box. Just the PFS version of the TEC3.
Discussion Starter #15
Kane
I originally paid $6999 for the kit, it was suppose to have the TEC3 but then I received a Haltech E8 and MSD DIS-4 instead. Due to some issue with Toyomoto not giving the wiring instructions and base map, I sent the E8 and MSD back and got a refund of $2200 so the hard pipes were $4799 plus the price of a used TEC3.
^^ damn good price right thuuurrrr.....
let us know when you get this bish running
i never said the BL kits were expensive to begin with ;)
stupid but why is the vvti left unplugged?
1 - 20 of 118 Posts
