So I apologize for my shitty camera...
The JDM dash kits plastic looks the best, but its fit and finish leaves much to be desired in terms of the gapping around the double din nav screen.
Its very simple, although a litlte time consuming, and definitely less expensive to do this yourself!
Buy the metra install kit from best buy, circuit city, etc.. It's about 15 bucks.
Buy some plastic epoxy.
Assemble the dash kit, per the instructions... once its put together, simply epoxy the "gap" between the trim bezel, and outer portion of the dash kit.
Be sure you use extra epoxy, so that it is not sunk down, as you'll need to sand to an even finish.
Let the epoxy cure overnight, so it becomes rock hard.
Gradually sand the entire piece, starting with 60 grit, working up to 600 or so, to make it perfectly smooth.
This gets rid of the disgusting texture on the kit, as well as making the gap disappear.
Finally, paint the kit with everyday flat black spraypaint. Be sure you use between 6 and 10 coats. You can clear coat after if you wish, but its unneccessary.
Here is the finished product, without the back pieces attached.
