So I bought AndrewW's MOTON Clubsport dampers. These dampers are truly #1. They feature 2 way adjustable, remote reservoirs, gas-lifting, 1000lbs springs, quick disconnects. The entire set up is worth $6000 easily. This is the best suspension in the world!!!
You would think that 1000lbs springs would send a daily driver teeth-chattering down the 401...... but in fact, this set up is SO COMFORTABLE on the street, and immediately you can tell that the car is just so flat in every corner. These dampers are really magical. I can't wait to get them out on track, but here are some pics from the install.
MOTONS in their box:
Out of the box:
Pillow ball top mount close up:
Damper body, close up:
Canister, close up:
Hole we had to drill to let the quick disconnected canister line go through. Note that we didn't have to drill a hole the SIZE of the canister due to the quick-disconnects. This makes the holes a LOT smaller!:
The hole from inside the trunk. We used nice grommets to keep the lines from chafing:
Rear damper:
Finished set up in the rear:
Front damper:
Front canister right side mounted up:
Front canister left side mounted up
Out of the box:
Canister, close up:
Rear damper:
Front damper:
