On the sides of the roof there is that strip of rubber like material that is different then the car. For a while now theres been mold and crap all over it. Theres giant black marks all up and down each side. I've tried everything to get it off...wash, wax, claybar, nothing works. Anyone else experience this? Also, will this be covered under the 72 month corrosion warrenty?
Is this the rubber seal on the outside? You may want to try a diluted mixture of warm water and bleach. Be careful when you apply it and make sure you wash everything off well with a hose after. This may remove the mold. If not, see about replacing it, check to see if it is covered by the dealer or DIY.
Are you talking about the top 2 strip of moulding on the roof that rans from front to back??? Can you post pics of the affected area??
yup thats it....ill have some pics up tomarrow
