I'm doing my timing belt today. It had been replaced once prior to me owning it. I have the crank at TDC/0, but the cam gears are off (I haven't removed the belt yet). The "dots" are lined up with the notches in the cover, but the hash marks on the gears are still at about 11 O'Clock. In other words, it seems whoever did the replacement last put the belt back on with the dots lined up instead of the hash marks. I guess that means they retarded the valve timing. I have had the car for a couple years and it runs fine.
First, am I correct thatthey were wrong to line up the "dots"? Secondly, I plan to put it back together with the hash marks lined up with the notches in the gear cover. Does anybody see a problem with this?
Thanks
Thanks
