2002 Lexus IS300 2JZGE
Hi everyone, I’ve been considering purchasing the Megan racing strut bars for my 2002 IS300. Will the strut bar fit even with the OEM engine cover installed? I love the look of the stock engine cover and would prefer to keep it. Do you think I would feel a difference even with my stock suspension? Planning on getting front and rear strut tower braces. Thanks!
I have the same question about the Megan racing bar:)
2002 Lexus IS300
I can’t tell you if it will fit with the engine cover unfortunately. I can tell you that if you have driven your car hard through turns for quite some time, you are keen to notice a difference in front end rigidity. It will be slight to some, but to others it will be a noticeable difference.
I just put the rear one on my car a few weeks ago and was surprised to have noticed a small difference. The rear just stays slightly flatter on turns. With both you should notice an improvement, especially on stock suspension.
2001 IS300, E-Shift, CXRacing Turbo Kit, 9:1 Compression, BC264 Cam, ECUMaster Black
To add my two cents, I thought installing the strut bar made my front end seem like it had more turn in response, after doing big brakes and running a spacer that snappiness seems to have left lol.
