Hi everyone, I have a question about front camber. What's the maximum degree of camber I can get in the fronts with stock FUCAs and the camber bolts? I'm currently running Megan FUCAs but they're banging too much at my height (about 1.5 inch from fender to lip). Would stock FUCAs bang less as well? TIA.
They should not be hitting at that height. Post a picture from the side and with the wheel off. But suspension loaded.
I've got -3.3 lowered 1.9" stock fuca but 15mm rca. which places fuca as if I'm lowered 15mm more.
Sent from my Pixel 4 XL using Tapatalk
They're banging the strut tower because the car is too low. The Megan arms have less clearance than the stock ones, to get it to stop you need to raise your suspension up or cut and weld your front spindles. Read this and you'll know what's up:
or you could manipulate the motion ratio by upping your spring rate. if you track the car it has a lot of benefits. if you park it, you won't even notice it. if you daily it, it's not bad, just depends how good your shocks are. I recommend digressive valving. gl hf.
That is what I said. Thanks!
