101 - 101 of 101 Posts
Well, the 200mm 3.55 or whatever it is, is the tallest that will fit in the stock pumpkin. It’s what I have, but I have an AR5. It makes for pretty good cruising rpms. Any taller gearing and you have to go to a GS300/SC430/etc 220mm diff, offset axles, and custom mounting. M85 is 3.73, so going down to the 3.55 isn’t a huge difference, but is noticeable.
You may have already seen this site but check out Is elite. There’s some good charts and data on the transmissions and diff ratios.
