First off, I've used the search function and came up empty handed on my particular problem, plus my scenario is a little different.
2002 IS300 auto to manual swap.
Bought the car a month or so ago and drove it for abut a week before parking to tie up some loose ends. The swap was done correctly using all factory parts from a wrecked manual including the ECU. I'm assuming the only key I have is the OG master key and the person who did the swap took the car to have the manual ECU and OG key linked/programmed to one another because it opened all doors and started the ignition fine for the week I drove it.
fast forward to about three weeks ago... One of the loose ends was swapping the auto wiring harness for a 03 manual harness which was the only thing they did not do in the swap. I installed the manual harness and now the car does not recognize the immobilizer. They security light flashes when the key is installed and the car will not turn over.
Security light did not flash the initial week I drove it and had no issues with the vehicle
-I've pulled the EFI relay and fuse while battery was disconnected
-Starting battery new and charged
-Key fob locks/unlocks the doors and pops the trunk
-Key will rotate in the ignition and the fuel pump will prime
-All lights inside and out work.
Is there a relearn for the immobilizer or a security rest?
Thanks in advance.
Thanks in advance.
