man... so I learned two things on saturday,
first thing... particle wood is weak sauce... it keep breaking on me when I put a screw in... I tried to ignore it
second thing... fiberglass cloth likes to break... it's awesome that it rips so easy, so hen you can just rip and add cloth where you need it... but man, that stuff broke down on me the first 5 mins..
(use fiberglass mat (not cloth) if you are going to cover a big spot. the cloth is stronger after you put the resin and hardener on though.
I ended up quiting on this box because the particle wood wont cut it and I messed up on the fiberglassing
it looks like a disaster.. do not use particle wood :disagree: I'm going to call this my practice enclosure
welp.. I bought plywood sunday night and started all over. took about an hour to cut all the wood so the box would fit the weird shapes in the trunk... try counting all the screws in the box... this bz is airtight
I stuck with the box like enclosure so I could calculate the amount of shape I have inside the box (it's from 2.5 ~ 2.7 cubic feet)
then I started ripping all the fiberglass cloth to figure out how I was going to put it on without it ripping on me again
apply a little resin and hardener (I'll finish the bottom of it when the top part dries)
If you look closely you can see my dog's footprint. she was licking and sniffing the plywood... what's up with that?
home depot ran out of fiberglass resin... I need to wait til the 21st... :wtf:
I am pretty happy with it so far. I am going to try to finish up putting all the resin and hardener on today after work (theres another home depot on my way home from work, so I'll buy a gallon of fiberglass resin there) so I could post a picture up before I attempt to sand and paint it.
(the title says, "Trying to DYI fiberglass" I really meant I'm trying to do it myself fiberglass... LMAO I hope no one misunderstood me.)
Pricing:
Plywood: $22
Fiberglass Resin and Hardener: $15 (so far; I'm going to need a gallon more so add $30 more)
Fiberglass Cloth: $7
Extras:
Screws: $7
Jig Saw: $30 (cheapest one)
Respirator: $3 (pack of two)
Gloves: $5 (pack of 10)
Paint brush: $0.7 each (get atleast 2)
Note for anyone who wants to make a fiberglass enclosure:
if you are debating over a full fiberglass enclosure (taping the inside of your trunk and applying resin inside the trunk) or what I did (wood box)... do what I did because the resin smells like butthole and the smell will haunt your car for 3 days... it's also not that great to be inhaling the resin gases.. felt like I was smoking (never smoked before so I am just guessing that's what it would feel like)
