Does anyone know where the "axle shaft flange bolts" are? (hopefully a picture that points it out)
And what is the torque spec?
Thanks in advance!
Here is the 10k mile maintenance checklist
IS350 10,000 mile service:
Replace engine oil and oil filter
Measure thickness of front brake pads and rotors (GS 430, IS)
Replace air conditioner filter (GS 300, GS 430, IS 350, LS 430, SC)
Re-torque axle shaft flange bolts (all models except ES)2
Rotate tires (all models except IS with different size front and rear tires)
Visually inspect brake pads and rotors
Road-test vehicle
Inspect the following:
____Axle shaft boots ____Nuts and bolts on chassis
____Ball joints and dust covers ____Steering linkage and boots
____Engine air filter
Thanks in advance!
Road-test vehicle
