VVTIS said:
If the rear main seal is leaking, where does the oil end up? On the ground? Or in the engine?
Well, the oil STARTS in the engine crankcase, where it belongs.
It leaks through the RMS into the bellhousing behind the flywheel. It then runs onto the spinning flywheel, which throws the oil via centrifugal force outwards, coating the entire interior of the bell housing with oil. The oil contaminates all of the parts inside the bell housing.
On an auto, you're fine if it's just a slow leak, as the torque converter is a fully encased unit.
On a manual, the oil gets on your clutch and causes it to slip, and to roast shortly thereafter. My brand new RPS 6-puck disintigrated in a matter of weeks, even though it didn't "feel" like it was slipping. The flywheel side was completely glazed over and not much material was left.
Eventually, the oil works its way down and exits through a small drain hole in the bottom of the bell housing, where it mates with the rear upper pan of the engine.
When your rear main seal goes, you will definitely notice an oil leak. You will have progressively more and more oil on the floor of your garage.
-Chris
