Before i show you the pics and progress. I want to let everyone here know that
Gabe (Lexguy300) did most of the work you are about to see. He's a super cool guy, and knows what he is doing. I would highly recommend his help to anyone in So Cal who needs help with any kind of mechanic work done. Also, shout out to
Dangishchris for referring me to Gabe, helping out with the oil pan, and the entire build, and keeping company on the way to Gabe's.
So it only took about 2 hours to get everything done, which was amazingly fast (excluding the time it took to wait for the sealant to dry).
Engine lifted:
Oil pan out:
Cleaning the residue off the sides/inside
Cleaning done, dont mind the paint scratches:
Hole drilled to -10an, with 3/8 threading:
...And this is why you take off the pan to drill the hole...unless you want this metal catastrophe distributed throughout your engine:
Fits like a glove:
Back to the oil pan, we used this sealant:
back to the top! or bottom, i should say:
We let the sealant set about 2 1/2 hours before putting in the new oil (Mobil 1 synthetic 5w-30). Drove back home for another 2 hours or so, still no leaks now, looks like its sealed up pretty good. And i am not using the barb fitting for the oil drain, it was given to me from an old and dated oil drain/receive xs power kit. as of now its capped off and will be replaced with something more...
fitting ha. NOW ON TO TURBOO! stay tuned.
