1 - 2 of 2 Posts
Alguien que me pueda ayudar tengo un problema con mi is300 la liz de bateria nunca se apaga ya cambie la bateria el alternado y cambio los cables de bateria y revise todos los fusibles y todavia sige en sendida es mi primer is300 y la verdad nose nada sobre esto. Este is300 no tiene sunroof es del año 2001 y el interior no es de piel la verdad nose que sea hay gien que me pueda ayudar a resolverlo
"Someone who can help me I have a problem with my is300 the battery light never turns off and I change the battery the alternating one and change the battery cables and check all the fuses and it is still in sendida it is my first is300 and the truth is nothing about this. This is300 does not have a sunroof, it is from 2001 and the interior is not leather, the truth is that there is someone who can help me solve it"
If you post in English you will get help quicker. Also in the right section. I moved it for you.
Now to confirm. You changed the alternator also? Right.
1 - 2 of 2 Posts
