To give some backstory, originally I was having a problem where after driving for a period of time, I would lose all response from the electric portion of the throttle and could only get a response once it pulled the throttle cable, so I originally tried to fix the APPS from research, replaced that part along with connectors for the apps and throttle motor connector (they were broken from the previous owner) and came back to the same problem, but now accompanied by a struggle to idle on start, that then levels out if I hold the throttle for 30-40 seconds. Then replaced the TPS and adjusted it to 14.9% which didn't change anything. Picked up a used throttle body to try and replace it with, but I'm wondering if there is anything else that could be the problem. Wiring to the APPS maybe?
