1 - 8 of 8 Posts
HI,
I have part of my rear bumper loose and I don't know if there is a clip or bolt that needs to be replaced. How can I fix this?
136151
136152
136153
136154
2002 Lexus IS300
@ill_mannered @TobiasSing
Thanks, I will look under to see if the clip is still there...
It’s still there 100% or else the entire part of that bumper wouldn’t be attached. Just go push on it firmly and see if it clicks into place.
Worse case is the little screw on that side has come loose or fallen out. If you look straight up under that lip behind the splash shield.
1 - 8 of 8 Posts
