1 - 8 of 8 Posts
I'm trying to put IS rims on my camry and I was told I can only mount them on with stock lexus is lugs. I found a set of IS Rims but they have no stock lugs so I'm wondering if anyone could hook me up with them for cheap. Or if you have a set of stock rims with the lugs that you want to unload, let me know.
Thanks, and I hope this post isn't offending anyone as I tried to place it in the sale/trade section but I can't
Thanks!
The lugnuts aren't anything special. You can get them at some auto parts stores. The stock IS300 wheels do not use a tapered lugnut. Instead they use a lugnut with a flat mating surface, and a washer inbetween. Just make sure the lugnuts you get for your camry are not tapered, since the IS300 wheels have no taper on the rim. I'm not sure about the stock camry alloy wheels, they might requite tapered lugnuts or they might be flat with washers.
1 - 8 of 8 Posts
