1 - 1 of 1 Posts
I'm considering replacing my HID headlights with LED headlights. I'm currently using HID and my passenger headlight will go out while driving, then turn back on when I switch the lights off then back on. I've read this is likely due to my Ballast going bad. If I replace the HID bulbs and Ballast I'm going to do both Ballasts and both low beam bulbs while the front bumper is off. I'm considering switching to LED headlights because I read they don't require a Ballast or can be compatible with a Ballast. I figure the price of 2 Ballasts + 2 HID low beam bulbs is nearly the if not more than LED bulbs.... Anyone have any LED bulbs they recommend, or any opinion why I should stay with HID?? I'm also going to buy 2 new chrome OEM Headlight housings (which I believe don't come with Ballasts typically), if anyone has any recommended sites to order some new.
1 - 1 of 1 Posts
