1 - 2 of 2 Posts
All,
I've got a '95 SC400 which some absolute tosser bumped the other day and I now have a dent just next to the joint with the rear fender on the drivers side.
I think it should be a fairly easy repair since the dink is accessible through the trunk and a few taps with the right tools should be able to work the damage out.
Unfortunately the a**hole chipped the paint and the area is going to require refinishing. While it's at the shop I'll get the rear and front fenders done too - might as well.
It's really important that the job is first rate and done by someone who understands how to match and blend metallics and use the right amount of flex in the paint mix – too often you see apparently good fender jobs craze and cobweb at the slightest hint of pressure – the result of an incorrect paint mix.
Any recommendations for a great body shop in the GTA??
Thanks.
Post this questions in the Canadian Forum...
http://my.is/forums/f122/
Do you have a white SC400 that's lowered on aftermarket rims?
1 - 2 of 2 Posts
