1 - 20 of 21 Posts
I am selling my built 2jz-ge short block.
This block was originally from an SC300. I used it for 400 miles after I blew my GTE block. This block has been Machined by Joe at THE MACHINE SHOP here in Orlando.
GE Block It has a .020 over bore.
CP Pistons .020+
Total Seal Gapless Race Rings
Eagle ESP H-beam rods
ARP 2000 Rod Bolts
Clevite77 main bearings
Clevite77 rod bearings
Clevite77 thrust washers
IS300 oil Pump
.035-.042mm oil clearance on rod bearings
.027-.038mm main journal oil clearance
ASking Price $1800
-I have a spare motor build. Fresh build. the block was honed by JOE at The Machine Shop in Edgewood, FL.
I have a 2003 GE bottom end with a matching 2003 GE vvti head. Selling as a longblock with no manifolds or accessories. this build has ZERO miles.
.034-.042mm oil clearance on rod bearings
.027-.035mm main journal oil clearance
GTE crank
GTE rods
GTE pistons
GTE Oil pump
GTE Head Gasket
ARP head studs
Asking Price $1800
-2JZGTE 98+ Aristo Stock Turbo Cams. These are stock Toyota Cams that you can drop into your vvti head with no modification. No need to mill your head or regrind your cams. pnp.
$450.00
-water pump $50 2 available
-Starters $50 3 available
-AC $50 1 available
-Alternator $50 3 available
-Black leather interior $650 2 front seats and rear seats.
-HKS SSQ BOV $100
Pics Available upon request.
all the accessories are used some are ge and some are gte. but all are good for the ge.pulley driven
Discussion Starter · #6 · (Edited)
I am not sure how much power they will make but I'm sure they will give you atleast a faster spool up, and optimal timing for a boosted application. These are stock vvti turbo cams and they have to be more aggresive than the ge ones an an IS300. I don't have a tool to measure the lift of these or I would
If I buy the cames will you sell me the cam covers?
all pms replied
Is anyone using those cams in their GE head? I've been searching and can't find much info on 'em.
would you just sell the head only??
I don't think anyone is using these cams on their GE bevcause they are so hard to come by. This is a JDM part that is not imported on its own, I have had several swaps and that is the only reason I have them.
I just added another short block
Wow...u went through quite a bit of hardware there. Good luck on the sale.
1 - 20 of 21 Posts
