1 - 18 of 18 Posts
I was wondering where do you insert the navigation disc on a oem navigation system. I have a 2002 lexus is300 with a motorized oem navigation and i can't find a place to insert the navigation dvd. Please help me!!!
Trunk on the right side under the mat thingy.....i think??
in the trunk bro. keep the keys in accessory or ON position when changing. you'll need a ratchet to remove the metal cover
push the eject button :suspiciou
After you remove the cover, there is a small plastic button that you have to slide up and it opens the DVD slot and ejects it.
help
i tried that and it didn't work. I slide the cover over and it opened. But the dvd didn't come out. and I can't put the new dvd in. I'm not sure if there is anything in there.
..Delete
Oh wait... I missed that you cant put the new one in. Your DVD drive may be hosed. I would take it out and take it apart if you're out of factory warranty.
did you leave the key in accessory or ON like i told you above?
1 - 18 of 18 Posts
