1 - 20 of 35 Posts
well i've always been wanting to do this so i finally got around to doing it i had relocated the traction control button. been wanting it in the middle but would only slide into both ends. so i had grinded down part of the top of it and put it in the middle hope you like because i do:)
this is all I saw.....
dude did you say grinded? :flee:
I moved mine when I took the radio out one day... I don't know why you had to grind anything... It just snaps in... It's not rocket science. Now if you had actually relocated it instead of moving it a place over then you would have a reason for a new thread...
I guess you can do this for symmetry... but I kind of like the trac button close to the driver. If you ever need to turn it off quickly... you just drop your hand down from the steering wheel... and your hand is pretty much infront of the button. (probably why they put it there in the first place)
Discussion Starter · #16 ·
if you know your car you wont have to look down. and i rarly shut my traction off anyways this is just me weekend car
But your Trac button is not relocated!!!!11111!!!ONE
1 - 20 of 35 Posts
