Does anyone have a list of the dealer-programmable options for the IS?
I'd like to change a few things like number of key-fob presses for opening the hatch (SportX) and notice there are a number things you can program according to the manual. When I take it in, I'd like to customize all at once. Couldn't find anything about this in the archives.
TIA--
I'm interested too.
I'd like to turn off the beeping sound for when the key is in the ignition and the door is open...
don't know if I can get away with it ... if it's related to state law...
threequartersx2 said:
I'm interested too.
Remove plastic panel under the steering wheel. It has 3 screws and 2 tabs. You will need to pull on it to make it loose. Con-holders is the best spot to grab on on the left. Once it is loose, remove temp sensor and hood release wire.
Remove metal plate - 2 screws.
This will give you access to the ignition lock.
All you need to do is pull of 2 wire connector that has key-sensing in it.
I used to do it when I was working on my car to stop the annoying beeping.
