1 - 11 of 11 Posts
idmax i2d2
some of my .net friends got me a sub and amp for my bday
idmax sub 12" i2d2 and a crossfire 600 watt amp.
I listen to mostly Rap and music like that
i like bass to be good in the car and outside also
What box should i get for 1 12?
this is my first time with bass , so work with me here.
thanks
David
Threadlocker
bass will be good. don't know if 600 watts is enough to truly power the idmax 12 though. i believe it handles 1000w rms.
for rap music and such i would get a sealed box for cleanest sound... you can find the space requirements in the install manual or whatnot or get them on imagedynamicsusa.com
to save space you can get a bigger amp and try running it infinite baffle.. not sure where to mount it for freeair though.
well if it is only 600 then i don't have to worry about blowing the 12?
David
Useless
is300soon said:
idmax i2d2
thanks
David
I would recommend a 2.5 cu' ported enclosure. It will be loud!!!!
Legacy Mod
typically you don't blow speakers by over powering them, but rather running the wrong ohm level like 2 ohm to a 4 ohm speaker for extended periods of time also you can have lots of extra distortion by under powering your speakers. just an FYI
David
But i should be fine with the 600 watt amp powering it?
Or will it sound off?
David
Discussion Starter #7
the amp is the crossfire VR602
David
Useless
David
It will work just fine!
Discussion Starter #9
im looking for a 1.6 cf enclosed box, you think i will have to have one made?
David
I bought a idmax from lisnup and built a 2.4 ft^3 box and it f'n pounds. You can feel you hair move.
Talk to lisnup, I bought my gear from him and had a 100% positive experience, stand up guy. Plus I bugged the shit out of him with questions because I did all the work myself, and I'm no expert.
Threadlocker
David
you can generally find 1.5-2 cu ft boxes at your local stereo shop. just make sure it's at least 3/4 inch thick mdf and well built.
also, make sure the box gives enough backspacing for the sub you are using
1 - 11 of 11 Posts
