1 - 14 of 14 Posts
I think my cars on limp mode. Revs won't go past 2.5k, stuck at 20/30kmph.
Cleaned the MAF, in fact I replaced it recently earlier this year.
Changed out all 4 o2 sensors over a month ago.
Just changed the diff fluid, transmission fluid and power steering. It was fine after that, although I suspected it wouldn't shift to third gear, but when I went to turn it on again the second time, still the same issue.
I also hear weird grinding/clunky noises from time to time from beneath the car when driving
NO Cel, and throwing no codes either
2002 Lexus IS300
Any pending codes?
You can still get codes thrown without the cel coming on, just depends on what the ECU determines as critical or not. Best if you can plug a code reader in and know for sure.
Discussion Starter #8
Update. I disconnected the battery last night and reconnected it this morning. I drove it around the block and it shifts to third and fourth gear without making any sounds, but not fifth. the engine has a roaring sound and won't rev past 2500
Discussion Starter #9
Second update. Just went for a longer drive, the car shifts in manual mode but not in automatc, it stays in gear 2. I was able to reach upto 80kmph, but i couldn't get uphill very well. The cars engine still sounds like it's roaring, much louder than usual
2002 Lexus IS300
If you have a scanner capable of reading PENDING codes please try that. Most scanners will ONLY read stored (ie CEL light is on) codes.
It seems like you have a possible shift solenoid failure or speed sensor failure. Does your Speedo work?
Discussion Starter #11
No I don't have a scanner unfortunately. and when my mechanic used the scanner it didn't throw up any codes. The speedometer works fine
Even if the tranny does not shift. That will not stop it from going above 2.5k.. It sounds like the stepper motor on the throttle body. Or a bad TPS or APP sensor.
1 - 14 of 14 Posts
