I am getting my set of 19" Lexion 203's tomorrow and I am wondering if the light weight lug nuts are worth it?
Next is a change up on the rotors and pads.........
slotted rotors and a good set of pads, ss lines as well....
suggestions for all of the above. I am not sure if I should go with the Brembo replacements?
If wheel weight is an issue, you shouldn't be running 19" wheels.
weight is not an issue I just did not know if it was worth it to try and off set some of the added weight.....
you will save only a few ounces at most....it aint worth it unless you are a professional racer. Which probably means you wouldn't be running 19" rims.
