1 - 1 of 1 Posts
from BAT Auto Technical-Professional mechanics giving advice-An Educational Site w/ OBD2 Trouble Codes and Technical info & Tool Store. thanks to a discovery by 300iss a couple years ago.
<table align="center" border="1" cellpadding="5" cellspacing="0" width="69%"><tbody><tr><td valign="CENTER" width="18%"> P0100
</td> <td valign="CENTER" width="82%"> MAF Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0101
</td> <td valign="CENTER" width="82%"> MAF Circuit Range/Performance
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0110
</td> <td valign="CENTER" width="82%"> IAT Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0115
</td> <td valign="CENTER" width="82%"> ECT Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0116
</td> <td valign="CENTER" width="82%"> ECT Circuit Range/Performance
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0120
</td> <td valign="CENTER" width="82%"> TP Position Sensor/Switch ‘‘A’’ Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0121
</td> <td valign="CENTER" width="82%"> TP Position Sensor/Switch ‘‘A’’ Circuit Range/Performance
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0125
</td> <td valign="CENTER" width="82%"> Insufficient Coolant Temperature For Closed Loop Fuel Control
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0130
</td> <td valign="CENTER" width="82%"> HO2S Circuit Malfunction, Bank 1 Sensor 1
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0133
</td> <td valign="CENTER" width="82%"> HO2S Circuit Slow Response, Bank 1 Sensor 1
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0135
</td> <td valign="CENTER" width="82%"> HO2S Heater Circuit Malfunction, Bank 1 Sensor 1
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0136
</td> <td valign="CENTER" width="82%"> HO2S Circuit Malfunction, Bank 1 Sensor 2
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0141
</td> <td valign="CENTER" width="82%"> HO2S Heater Circuit Malfunction, Bank 1 Sensor 2
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0150
</td> <td valign="CENTER" width="82%"> HO2S Circuit Malfunction, Bank 2 Sensor 1
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0153
</td> <td valign="CENTER" width="82%"> HO2S Circuit Slow Response, Bank 2 Sensor 1
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0155
</td> <td valign="CENTER" width="82%"> HO2S Heater Circuit Malfunction, Bank 2 Sensor 1
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0156
</td> <td valign="CENTER" width="82%"> HO2S Sensor Circuit Malfunction, Bank 2 Sensor 2
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0161
</td> <td valign="CENTER" width="82%"> HO2S Heater Circuit Malfunction, Bank 2 Sensor 2
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0170
</td> <td valign="CENTER" width="82%"> Fuel Trim Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0171
</td> <td valign="CENTER" width="82%"> System Too Lean (Fuel Trim)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0172
</td> <td valign="CENTER" width="82%"> System Too Rich (Fuel Trim)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0174
</td> <td valign="CENTER" width="82%"> System Too Lean (A/F Lean Malfunction, Bank 2)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0175
</td> <td valign="CENTER" width="82%"> System Too Rich (A/F Rich Malfunction, Bank 2)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0300
</td> <td valign="CENTER" width="82%"> Random Misfire Detected
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0301
</td> <td valign="CENTER" width="82%"> Misfire Detected, Cylinder 1
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0302
</td> <td valign="CENTER" width="82%"> Misfire Detected, Cylinder 2
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0303
</td> <td valign="CENTER" width="82%"> Misfire Detected, Cylinder 3
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0304
</td> <td valign="CENTER" width="82%"> Misfire Detected, Cylinder 4
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0305
</td> <td valign="CENTER" width="82%"> Misfire Detected, Cylinder 5
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0306
</td> <td valign="CENTER" width="82%"> Misfire Detected, Cylinder 6
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0307
</td> <td valign="CENTER" width="82%"> Misfire Detected, Cylinder 7
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0308
</td> <td valign="CENTER" width="82%"> Misfire Detected, Cylinder 8
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0325
</td> <td valign="CENTER" width="82%"> KS 1 Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0330
</td> <td valign="CENTER" width="82%"> KS 2 Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0335
</td> <td valign="CENTER" width="82%"> CKP Sensor ‘‘A’’ Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0340
</td> <td valign="CENTER" width="82%"> CMP Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0385
</td> <td valign="CENTER" width="82%"> CKP Sensor ‘‘B’’ Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0401
</td> <td valign="CENTER" width="82%"> EGR Insufficient Flow
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0402
</td> <td valign="CENTER" width="82%"> EGR Excessive Flow
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0403
</td> <td valign="CENTER" width="82%"> EGR Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0420
</td> <td valign="CENTER" width="82%"> Catalyst System Efficiency Below Threshold Bank 1
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0430
</td> <td valign="CENTER" width="82%"> Catalyst System Efficiency Below Threshold Bank 2
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0440
</td> <td valign="CENTER" width="82%"> EVAP Emission Control System Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0441
</td> <td valign="CENTER" width="82%"> EVAP Emission Control System Improper Purge Flow
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0446
</td> <td valign="CENTER" width="82%"> EVAP Emission Control System Vent Control Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0450
</td> <td valign="CENTER" width="82%"> EVAP Emission Control System Pressure Switch Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0451
</td> <td valign="CENTER" width="82%"> EVAP Control System Pressure Sensor Range/Performance
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0500
</td> <td valign="CENTER" width="82%"> VSS Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0505
</td> <td valign="CENTER" width="82%"> Idle Control System Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0510
</td> <td valign="CENTER" width="82%"> Closed TP Switch Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P0550
</td> <td valign="CENTER" width="82%"> Power Steering Pressure Sensor Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1100
</td> <td valign="CENTER" width="82%"> BARO Sensor Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1120
</td> <td valign="CENTER" width="82%"> Accelerator Pedal Position Sensor Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1121
</td> <td valign="CENTER" width="82%"> Accelerator Pedal Position Sensor Range/Performance Problem
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1125
</td> <td valign="CENTER" width="82%"> Throttle Control Motor Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1126
</td> <td valign="CENTER" width="82%"> Magnetic Clutch Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1127
</td> <td valign="CENTER" width="82%"> ECTS Actuator Power Source Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1128
</td> <td valign="CENTER" width="82%"> Throttle Control Motor Lock Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1129
</td> <td valign="CENTER" width="82%"> Electronic Throttle Control System
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1130
</td> <td valign="CENTER" width="82%"> Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1133
</td> <td valign="CENTER" width="82%"> Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1 Sensor 1)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1135
</td> <td valign="CENTER" width="82%"> Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1150
</td> <td valign="CENTER" width="82%"> Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1153
</td> <td valign="CENTER" width="82%"> Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 2 Sensor 1)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1155
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1200
</td> <td valign="CENTER" width="82%"> Fuel Pump Relay/ECU Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1300
</td> <td valign="CENTER" width="82%"> Igniter Circuit Malfunction (Bank 1 Or No. 1)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1305
</td> <td valign="CENTER" width="82%"> Igniter Circuit Malfunction, (Bank 2 Or No. 2)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1310
</td> <td valign="CENTER" width="82%"> Igniter Circuit Malfunction (No. 3)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1315
</td> <td valign="CENTER" width="82%"> Igniter Circuit Malfunction (No. 4)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1320
</td> <td valign="CENTER" width="82%"> Igniter Circuit Malfunction (No. 5)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1325
</td> <td valign="CENTER" width="82%"> Igniter Circuit Malfunction (No. 6)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1330
</td> <td valign="CENTER" width="82%"> Igniter Circuit Malfunction (No. 7)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1335
</td> <td valign="CENTER" width="82%"> CKP Sensor Circuit Malfunction During Engine Running
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1340
</td> <td valign="CENTER" width="82%"> Igniter Circuit Malfunction (No. 8)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1345
</td> <td valign="CENTER" width="82%"> VVT Sensor Circuit Malfunction (Bank 1)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1346
</td> <td valign="CENTER" width="82%"> VVT Sensor Rang/Performance Problem (Bank 1)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1349
</td> <td valign="CENTER" width="82%"> VVT System Malfunction (Bank 1)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1350
</td> <td valign="CENTER" width="82%"> VVT Sensor Circuit Malfunction (Bank 2)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1351
</td> <td valign="CENTER" width="82%"> VVT Sensor Range/Performance Problem (Bank 2)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1354
</td> <td valign="CENTER" width="82%"> VVT System Malfunction (Bank 2)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1400
</td> <td valign="CENTER" width="82%"> Sub-TP Sensor Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1401
</td> <td valign="CENTER" width="82%"> Sub-TP Sensor Range/Performance
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1410
</td> <td valign="CENTER" width="82%"> EGR Valve Position Sensor Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1411
</td> <td valign="CENTER" width="82%"> EGR Valve Position Sensor Circuit Range/Performance Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1500
</td> <td valign="CENTER" width="82%"> Starter Signal Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1520
</td> <td valign="CENTER" width="82%"> Stop Lamp Switch Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1565
</td> <td valign="CENTER" width="82%"> Cruise Control Main Switch Circuit Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1566
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1600
</td> <td valign="CENTER" width="82%"> ECM BATT Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1605
</td> <td valign="CENTER" width="82%"> Knock Control CPU Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1633
</td> <td valign="CENTER" width="82%"> ECM Malfunction (ETCS Circuit)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1645
</td> <td valign="CENTER" width="82%"> Body ECU Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1656
</td> <td valign="CENTER" width="82%"> OCV Circuit Malfunction (Bank 1)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1663
</td> <td valign="CENTER" width="82%"> OCV Circuit Malfunction (Bank 2)
</td> </tr> <tr> <td valign="CENTER" width="18%"> P1780
</td> <td valign="CENTER" width="82%"> PNP Switch Malfunction
</td> </tr> <tr> <td valign="CENTER" width="18%"> B2785
</td> <td valign="CENTER" width="82%"> Ignition Switch On Malfunction (Immobilizer System)
</td> </tr> <tr> <td valign="CENTER" width="18%"> B2786
</td> <td valign="CENTER" width="82%"> Ignition Switch Off Malfunction (Immobilizer System)
</td> </tr> <tr> <td valign="CENTER" width="18%"> B2791
</td> <td valign="CENTER" width="82%"> Key Unlock Warning Switch Malfunction (Immobilizer System)
</td> </tr> <tr> <td valign="CENTER" width="18%"> B2795
</td> <td valign="CENTER" width="82%"> Unmatch Key Code (Immobilizer System)
</td> </tr> <tr> <td valign="CENTER" width="18%"> B2796
</td> <td valign="CENTER" width="82%"> No Communication In Immobilizer System
</td> </tr> <tr> <td valign="CENTER" width="18%"> B2797
</td> <td valign="CENTER" width="82%"> Communication Malfunction No. 1 (Immobilizer System)
</td> </tr> <tr> <td valign="CENTER" width="18%"> B2798
</td> <td valign="CENTER" width="82%"> Communication Malfunction No. 2 (Immobilizer System)
</td></tr></tbody></table>
1 - 1 of 1 Posts
