1 - 10 of 10 Posts
i bought the LED strips to put on the headlights. I don't want to glue them on the outside, because it looks ghetto and someone might steal them.
Does anyone know where I can find the instruction to put them inside, I heard you need to remove the bumper or the lights, not sure.
I have an 07 lexus is 250
Here is where i bought it and
VLine - automotive accessory LED light (LED light strip)
You have to remove the lights, bake them, insert and install the leds, rebake the lights make sure you do a good job, then install them back on the car and hook the new leds to 12v.
Just like IS300SOON said it^^^ you have to bake your lights, open them up install them on the inside, and then bake to put them back together. I did it on mine, but i ran seperate wires to a switch, cause i want to have the capability to turn them on and off as I please.
Instructions
Ok and what do you mean by bake? i am sorry i am not very savvy on this. do you know anywhere where they have the instructions or who can install it?
here is the link I found and used.
DIY INFO: Black Headlight MOD! - Club Lexus Forums
and a video
the LED strips i bought had 3M adhesive on the back but the front also had an adhesive on it, or at least it felt like they did, and once i had the headlights open i placed it against the lens on the inside, they stuck to it and have been on for almost 2 months now, haven't had a problem, run the wires through the housing, you will notice a little black rubber boot behind the headlight, remove that and you will see an opening where you can run the wires through. I also painted my housing since i had the lights opened up. PM me if you have any questions.
Do NOT remove the boot, that is designed to sit there for a reason. There is a foam filter in it, this filter helps with regulating the heat inside the headlight.
D
Yes, good point, I completely left that out, when i said remove it, i meant just while you run your wires, make sure to put the boot back on! Thank you is300soon! good catch.
No problemo :)
D
Cool and to think I was going to purchase a '11 just to have those stock LEDs. :)
1 - 10 of 10 Posts
