Discussion Starter #2
I change the VVT solenoid and clean the filter and for the the P 1300 I changed the ignitor coils and spark plugs and it still has the same problem with the car shutting off
You need to replace the oil control valve for the vvti gear.
The P1300 could be related. But if not. Were the coil connectors in good shape? If so I would look at the connector to the ignitor. If it is good the ignitor may be bad.
