Hello guys I want you’re guys opinion you think 70 mm fender flares to big for a Lexus is300 was thinking of running 18x10 all around thanks.
Are you aware of the work needed to install these and to complete the look?
That's cutting, then rivet or molding the flares, then repaint
then you need new suspension, likely air suspension and alignment components
then you need some custom wheels with negative offsets
From your question it doesn't seem like the sort of job you're down for
