1 - 2 of 2 Posts
Lexus IS LED Turn Signal / Tail Light LEDs
(XP80 shown)
From the factory, tail light bulbs are powered by standard incandescent lights that light up white in color, and cast light through your red or amber tail light lens. This results in a washed-out color.
Newer luxury vehicles are using LEDs for turn signals, because LEDs offer a crisp, instant on/off function, increased brightness, and true, vibrant color. By replacing the bulbs in your Lexus IS, you can achieve this modern look!
Brightness
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb compared to factory:
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Bulb Design:
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Included in your order is TWO BULBS.
Front Turn Signal LEDs for Lexus IS (pair)
Rear Turn Signal LEDs for Lexus IS (pair)
Tail Light LEDs for Lexus IS (pair)
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
If you have any questions, please don't hesitate to post, PM, email[email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
1 - 2 of 2 Posts
