Lexus.com has IS '02 info now
660 Views 10 Replies 7 Participants Last post by  marke1
FYI
1 - 11 of 11 Posts
cool, it actually has specifications too!, here are some
Body type:
Five-passenger sport sedan
Construction:
Welded-steel unibody
Overall length:
176.6 in
Overall width:
67.9 in
Overall height:
55.5 in
Wheelbase:
105.1 in
Aerodynamic drag coefficient:
0.29
Weight distribution:
54% front/46% rear
Curb weight:
3,255 lb
Fuel-tank capacity:
17.5 gal
Trunk capacity:
See less See more
the stick is only 30 pounds lighter, wtf?
Is it just me or do the pictures of the 2002 interior still not have an armrest?
See less See more
Anyone know if the 2001 had the diversity antenna system? I don't recall that feature.
I believe the 2001 models do have it imprinted into the backlight (i.e., the rear glass). I think the radio switches between using the fuba roof antenna and the glass antenna (if not, then they probably work synergistically).
Grrr...they don't give out the gear ratios of the manual transmission...
See less See more
JW,
How do you read the gear ratio? i am learning. can you explian?
I sure hope the manuals turn a lower RPM in 5th than the auto. I can't imagine it being any higher.
The EPA highway mileage has increased from 23 to 25 for both the auto and the manual. Did they change the final drive ratio or something? The top speed is listed as 143.7 MPH - isn't that higher than before?
1 - 11 of 11 Posts
