2
Originally posted by Young:
All I am saying is that drivers and conditions being equal, the E46 M3 will be a better track car than the E39 M5. And I'd be willing to wager something real on it. The M5 has the M3 beat in luxury, but it's just very hard for me to believe that a lighter car with newer drivetrain technologies and the same or better accelerative capabilities is NOT better on the track. It just doesn't make sense. You're the very first person I've heard say that the M5 is just as good a track car as the M3. You must know something that a lot of M3 and M5 owners don't! Have you even driven an M5? I can't say I have. I did though test drive an E36 M3 and 540i back to back, and though the 540i may be significantly quicker in the straightaways, the cornering leaves much to be desired. The M5 may be a different beast, but it has the same weight problem the 540i has and the laws of physics have not been repealed.
You must attend the horse track very often. I make a living on speculation. I move 7 figures in and out of the markets everyday........
Open your eyes and observe the evidence instead of arguing just for the sake of it. The E39 M5 beats the E46 M3 in a straightline as well as on the track, according to ALL reported times so far. Either BMW did a godly job for the E39 M5 (a high-speed cruiser) or they under-engineered (relatively speaking) the E46 M3 (a sports coupe). But it is fact that the E39 M5 is better all around. I did test drive an E39 M5 several times before I placed the deposit. It is awesome and you should try too. As far as the understeer is concerned, it is tunable, otherwise how did the car perform so well on the track at 4,024 lb. I have already said, the E46 M3 should be more agile. But it is a little heavy as a sport coupe and hence, losing to a top-of-the-line high-speed cruiser on the track. As far as the straightline is concerned, I have already calculated the acceleration times and top speeds with the published gear ratios, HP numbers, RPM limit, torque numbers, wheel diameter,........ etc. They revealed that the E39 M5 (as long as traction holds) should be ~6 % more accelerative at any speeds plus the top speed is ~10 MPH higher. And they are consistent with the reported numbers so far. I do NOT need any popular support........
This is NOT to say the E46 M3 CANNOT be improved. But once again up-to-date, the E39 M5 is better all around.
