1 - 2 of 2 Posts
I was wondering if the control would work for my specific case?
I have a small problem with my lights after an accident they are slightly uneven and the Lexus dealer did not even work on them because I am not sure but believe it is not covered under my warranty. so anyway the indicator on the gauge cluster has the light not working picture.
I was wondering if the motors in the lights were broken or not and if the controller would fix the head lights not being even?
thanx for any input :chill:
If the lights still move through their self check when you put the key in the ignition with the lights on then you can use the controller. But the controller won't let you move one light or the other individually, you can only move them both together.
1 - 2 of 2 Posts
