1 - 2 of 2 Posts
I have a Blk Onyx 03, Each time I apply dealer touch up paint, I let it dry for a few hours, and apply langka. Langka seems so strong it melts right through the touch up paint and often wipes off... ... and I have to start all over... any tips or tricks from .Netters? Thanks in advance guys.
- Hobbes
Are you using the blue plastic card that came with it? Put a few coats of touchup paint and make sure it fills the hole. Take a tightly woven cloth like a t-shirt or bedsheet and wrap it around the card tight. Watch the area you touched up from an angle so you can see how much you're removing as you rub the area lightly. Once the surface is even take a clean cloth and remove any excess Langka.
1 - 2 of 2 Posts
