Ok, guys thanks for the help, but I must say, i can't believe no one on the net ever realized the stock front bar is HOLLOW!! I just installed them and the stock front bar weighed 7lbs, the L-tuned 15 lbs. There is a difference in the handling, but not huge, id say 50% less body roll, but 50% left is still alot it seems to me, but of course the rest of the susp. is stock, so after the springs it may be a different story. (im going with h&r's. Might install them next weekend.
I suggest don't ever pay to have sway bars installed, it took me an hour to do the whole thing, I guess assuming you have the resources to do it.
All thats needed is a floor jack, 2 jack stands, a 3/8" ratchet, a 10mm, 12mm, and 14mm socket, and maybe an allen wrench if the end link spins on you.
Can anyone help though again, for the rear bar it is 3 hole adjustable. I set it to the middle, but can anyone tell which way stiffen's and which way softens the bar? towards the front of the car, or towards the back of the car. I still don't know how to give rep, i'll give rep for the help so far, much appreciated in your all efforts in helpin a brother out.
