1 - 20 of 28 Posts
Received my L-Tuned exhaust used with about 5000 miles on it. Finally got around to installing it and wow!
The exhaust tip just clears the rear lip I have on it (L-Tuned), so no need to extend it.
The ride in drive gives you a noticeable rumble in low RPMs, and oddly enough, it quiets up after the car is moving. Once I'm moving and I give the gas something significant, the baby gives off this beautiful, unmuffled grrr. Slightly louder than the stock exhaust.
Overall, I am seriously impressed and very content with the quality of the ride. Exceptional! Of course this is all subjective, and if you're in the market for the L-Tuned exhaust, you won't be dissapointed.
I'm not about being loud, and this exhaust suits me.
Couple of things, when I received the exhaust, it was just the exhaust...I thought this was a catback? someone please clarify if I'm missing some piece?
Did the listing have any pictures for you to look at? That will tell you if you are missing a piece or not.
It's an axle back
Yes, it's an axle back. After I installed mine I noticed a bit more torque off the line.
There is B pipe(catback) that connects to your axle back (muffler), catback exhaust includes both the B pipe and the muffler, there's really no power to be gained with an aftermarket B pipe.
happysmp said:
Ah! what's an axle back vs the cat back vs the stock (whatever that was)
help out a noob
An "Axle-back" exhaust is basically an exhaust that connects to the stock B-pipe near the rear axle area and goes towards the back. A "Cat-Back" is basically an exhaust system that includes an aftermarket "B" pipe or resonator piping that connects starting at the Catalytic Converter...and heads out towards the back. :)
Discussion Starter #8
Thank you,
so the real question is...does the L-Tuned exhaust come with the B-Pipe? Or was it intended to be used with the stock B-Pipe?
What's the difference between the aftermarket b-pipe and the stock?
happysmp said:
Thank you,
L-Tuned exhaust is designed to be used with the stock b-pipe. Aftermarket b-pipes are usually a little larger in diameter, sometimes it has no resonator or made of a different metal.
it's a noticeable rumble in the low range...then oddly enough quiets up with more power.
I stuck the car in neutral and gave it a few good chops, and didn't hear the same rumble...
I"m lovin it...but honestly, just got it installed and still need to drive and paly
you give such wonderful explanations. haha.
where you at man? come stop by one of these days.
The L-tuned exhaust is rather heavy, and it tends to come loose after hard driving (i.e. on the track). Keep an eye on it.
happysmp said:
are you serious?!?!?
Yep. Several times one of the rubber donuts came loose, and I would just slip it back on. Finally, one broke, and I replaced it. I put some safety wire on, and I haven't had any problems since. No big deal.
Congrats on the new mod. I was considering one of these, but decided to stick with my HKS. Happy tuning!
That's not the fault of the exhaust...it's the failure/deterioration of the rubber hangers holding up the exhaust.
1 - 20 of 28 Posts
