1 - 1 of 1 Posts
KSPORT's Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. Made from high quality 6061 Aluminum with T6 for increased hardness.
Kontrol Pro
•36 levels of adjustable damping
•Made from high quality 6061 aluminum with T6 for increased hardness
•Compression/Rebound adjustable
•Adjustable spring perch for height adjustment
•Adjustable body allowing maximum suspension travel
•Pillowball top mount with adjustable camber (not available for some models)
•Monotube high pressure design reduces oil leakage
•Electroplated body for protection from corrosion and rust
•One year limited warranty
IS250 - 2006 ~ 2012 - - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS300 - 2001 ~ 2005 - JCE10 - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS350 - 2006 ~ 2012 - - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS-F - 2008 ~ 2012 - - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Rally Spec GR (Gravel) or Rally Spec AR (Asphalt)
•Special designed springs for rally conditions
•Extended Piston Stroke
•Reinforced internals to withstand extreme track conditions
•Made from high quality 6061 Aluminum with T6 for increased hardness
•Compression/Rebound adjustable, Adjustable spring perch for height adjustment
•Pillowball top mount w/ adjustable camber (not available for some models)
IS250 - 2006 ~ 2012 - - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS300 - 2000 ~ 2005 - JCE10 - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS350 - 2006 ~ 2012 - - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS-F - 2009 ~ 2012 - - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Version RR
•Aggressive valving and spring rates
•Race applications only
•36-way adjustable damping
•Pillow ball top mount w/ adjustable camber (not available for some models)
•Monotube High Pressure Design reduces oil leakage
IS250 - 2006 ~ 2012 - - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS300 - 2000 ~ 2005 - JCE10 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS350 - 2006 ~ 2012 - - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS-F - 2009 ~ 2012 - - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Slide Kontrol
•Inverted shock design (Most applications)
•Optimally designed for larger wheel/tire combinations
•Utilizes helper springs in the rear to increase stability and traction
•Heavy duty internals to withstand abuse
•Inverted Monotube high pressure design reduces oil leakage
IS250 - 2006 ~ 2012 - - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS300 - 2000 ~ 2005 - JCE10 - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS350 - 2006 ~ 2012 - - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS-F - 2009 ~ 2012 - - For Drifting - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Version DR
•Valved and sprung for drag racing; Proven to reduce 60 ft and elapsed times
•Includes shock dyno results, and tuned to your needs
•Adjustable spring perch for height adjustment, Adjustable body allowing maximum suspension travel
•Pillow Ball Top Mount w/ adjustable camber (not available for some models)
•18 Month Limited Warranty
IS250 - 2006 ~ 2012 - - For Drag Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS350 - 2006 ~ 2012 - - For Drag Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
IS-F - 2009 ~ 2012 - - For Drag Racing - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
GO TO NOPI KSPORT Catalog for model specific images and details
Contact the salesmen below or PM me for our best deal on KSPORT Coilover Systems
1 - 1 of 1 Posts
