For those of you with the HR/Koni setup, what settings are you using for your shocks, front and rear? I will be getting them installed on September 4 and I am thinking of setting them at one turn from full soft but would like to hear from those who have experience. I understand the fronts will be easy to change if I don't like the ride but I would like a good starting point for the rears. Thanks
One turn is a good starting point. If you have a big sub box, etc you may have to set the rears a little higher.
You'll have to balance them out to suit yourself, but you need to get the front and rear equalized so the car doesn't pitch a lot.
There's really a big range there. 1/4 turn an you can tell the difference.
I ride on one and a half turns front and back to keep the front from rubbing on turns. It rides stiff but not too stiff.
Thanks for replying. I got them installed one turn from full soft and they were plenty firm enough for me. The spring and shocks improved the ride much more than the sways did, removing most of the lean/squat and dive.
