Hey, I've been trying to find specs on the System E feature of the Kenwood 8017, what exactly are the specs on this crossover?
More specifically, could I send say.....2500hz and up to one 2-channel amp, 50-2500hz to another 2 channel amp(actually, a bridged 4 channel amp), and 200hz down to a sub amp with this H/U? Also, what slopes can you choose?
I'm not quite sure how all that would work, but I do know depending on if I can use the H/U, it will decide which amps I'll be using, because one amp has the great crossovers I could use, but the other amps put out a little more juice, so if I can use those higher output amps with the H/U crossover, that would be the best of both worlds......
Of course, I could always buy an active crossover for everything, but it would be great to have that crossover already built in for me to use and control from my H/U :>)
Discussion Starter #2
Anybody with experience with other Kenwood units that have System E crossover in them? I know plenty of you guys have this unit or the DDX7015! Has anyone used the crossover so they can give me some details as to what is possible?
someone pull out there manual or something and read up on this!
