1 - 8 of 8 Posts
K&N needs your 2004 IS300 for Intake Performance Kit development. The current Typhoon will not run efficiently on 2004 model years so we are redesigning the kit. Car will be needed for 5 working days. A rental car can be made available during the interim. Interested candidates please e-mail me directly at [email protected]
Thank you
Podiatrist
You'd wanna tell them where you are.
how is the 2004 different from 2002-2003 models that they need to redesign the intake??? :-?
K&N is a little behind....PLP apparently is about to get 2005 models to develop products for.....
:p
I moved my Area51 intake from my '01 to my '04 with no problmes...
Actually there was one small thing. In the '04 model Lexus added a few gears to behind the high beam bulb. If you don't know the Area51 intake touches the connector of the high beam.
The gears do this: When you adjust the low beam up and down the high beam is adjusted as well.. So when you turn one the gears turn the other..
Of course I took this off with two screws and my intake fit fine.
I hope you didnt install the Area51 BB....the ECU from the 2001 is different then the 2002-2004
goldark said:
oh man
2001
2002-2003
2004
same car - 3 different version of the ecu?
that hasnt been confirmed yet if the 2004 ecu is any different in wiring from the 2002-2003......I would assume not, why would they change it again?
Of course not......
I actually now have two area51 black boxes doing nothing... lol
1 - 8 of 8 Posts
