well for the alst 5 weeks ive been on a mission...literally..to chnage my setup from cast iron manifold and 60-1
too...
top mount ss tubular manifold with a 67mm wheel upgrade and a massive 4inch inlet 2.5 outlet polished compressor hosuing
now it was hard and i ahd to customise a lot of stuff..but afetr it all i finally started it today...it had no catback..no intake...but it ran smooth....
the only concern i ahve is the fact that when it warmed up it was super lean...now i kidna figured that id bring in more air with a bigger compressor wheel...but at idle iw as off the wideband chart.
im using a haltech f10x for a tune...
anyone have any first hand experiance with this?
basically i justw anna know if i should tow it up to get tuned or justd rive carefully
thanks
Matt
Yeah I would have someone send you a slightly richened map in order for you to go anywhere. Safe with fouled plugs than sorry.
You're going to have serious issues since you have no timing control with that fuel only standalone.
A 67 w/ stock timing....boom.
You need a full standalone for this.
dioes it need a little more retarding?
would the dis4 take care of this?
