Not really too bad, but harder than alot of cars. The first thing is lowering down the aero panel about 6 screws (10 mm). Then you can easily reach the oil filter. Also with out lowering the panel the oil from the drain plug will probably at first get up on the underside of the aero panel. The previous Lexus Tech had the filter on very tight which is usually the case. I had to loosen it with a filter wrench. Then I began to spin it off by hand. When I got close I slipped a baggie around it (advice from this board) and the baggie caught the oil which would have dripped all over. Previous Lexus Techs had dumped oil and it took me some time to wipe up the frame and engine area using rags and degreaser. I filled the new filter about half way with fresh oil before I spun it on. Any more and it would have spilled because of the angle the filter sits at. Also the oil filler on top of the valve cover does not allow a funnel to be put in. There is a sheet metal piece covering the opening. I believe this is done to reduce engine noise and would also prevent objects from getting into the valve train. I then added 5.7 total quarts of 5W-30 oil and I was done. While I had it up on jacks I inspected and cleaned the underneath. Interestingly the IS uses 2 seperate drive shafts with a universal joint in-between (reduce vibration?). The whole underneath is also covered with plastic aero panels. I cleaned the panels and applied Armor All to them. I also took the time to wipe down the steering linkage rubber boots and apply silicone to them and the other rubber components. "A clean car is a happy car"
[ July 20, 2001: Message edited by: mjdart ]
