I cut a arch out of the outer skin/fender first then slotted and hammered the inner skin upwards for integrity. I welded the inner skin back up, cut the excess off, and then sealed them off with fiberglass fillerHey, what was the process for cutting the rear fenders? One layer of metal or two? I might have to do some chopping this weekend. Lol.
Thank you. I had to get some advice before I went to hacking. Gotta clear some space to fit the low offset rears.I cut a arch out of the outer skin/fender first then slotted and hammered the inner skin upwards for integrity. I welded the inner skin back up, cut the excess off, and then sealed them off with fiberglass filler
Take your time, measure, and mask up areas to prevent fallout on the paint (If you're repainting you can kind of skip this)Thank you. I had to get some advice before I went to hacking. Gotta clear some space to fit the low offset rears.
Thank you!One thing I noticed... the plate mounting holes aren't there. But the trunk lid is gorgeous.
